It is currently Thu Sep 18, 2025 4:50 am
 Post subject: 2 piece sides
PostPosted: Fri Oct 22, 2021 5:54 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I was watching the flamenco guitarist Ben Woods playing a Cordoba guitar which had 2 different woods on the sides. One was very dark and one quite light in color maybe lacewood. I recently cut up some peach wood and sumac. and the material for the sides is not wide enough. Would you recommend bending both pieces separately and then gluing together or do you think I could glue them first and then bend. If so what kind of glue and what method of heating the sides would not result in the glue joint giving way
Mike McNerney
 Post subject: Re: 2 piece sides
PostPosted: Fri Oct 22, 2021 6:30 pm
Last Name: Kincheloe
Hot hide glue would probably do it. I've never tried two-piece sides, but I have done side purfling (single veneer strip) and bent on a hot pipe, and they're amazingly tolerant to the heat and moisture. They will fall apart eventually if you spend a long time at it, but until then, whatever portion of the joint does get wet should theoretically be reactivated by the heat so it should return to full strength when dry.
PostPosted: Sat Oct 23, 2021 11:21 am
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
I also have glued purfling to binding and then bent it but in a bender. Found that Titebond 3 worked best on holding it together. That's about the only thing I've used it for on guitars.
PostPosted: Sat Oct 23, 2021 11:41 am
Why not three pieces with two joined exterior pieces and a backer board. Double/laminated sides are used by some of the best Luthiers in the world such as Somogyi.
In the guitar repair business the word/name Cordoba is Spanish for bridge reglue. :)
Check out Howard Klepper's work and more specifically Dovetail Madness and Son of Dovetail Madness as well.
PostPosted: Sat Oct 23, 2021 1:44 pm
If I am not mistaken I think Fish glue has the highest temperature release of any of the normal glues we used. I used it on Slemer type guitar tops to bend the pliage on the top and had no problems but that is not as intense as bending sides too. The moisture might be an issue with either hide or fish.
PostPosted: Sat Oct 23, 2021 5:45 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I use titebond 3 when I glue up binding and purfling logs. They seem to bend fine without delaminating. For some reason, it feels different to me putting that joint in the middle log a side width but I have nothing to base that on.
Bryan Bear PMoMC
PostPosted: Sat Oct 23, 2021 6:43 pm
I built a pine guitar a decade or so ago out of a pine 2" x 4" (different story). I needed wider sides than 3 1/2 inches and edge glued more material to make them wider. Titebond 3. Everything bent on a pipe and is still holding well.
These users thanked the author Darrel Friesen for the post: jfmckenna (Sat Oct 23, 2021 6:58 pm)
PostPosted: Sat Oct 23, 2021 7:30 pm
First name: Carl
City: Forest Ranch
Might be interesting to have some purfling separating the two pieces.
PostPosted: Mon Oct 25, 2021 7:59 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
Bonjour mike . I/ve done quite a bit of gluing 2 sides together, and as others have mentioned, then laminating them with a thin veneer. The product that has worked for me is UF glue made by dap ? I get it from walmart ace hdware,and amazon it is a 2 part glue that is mixed with water . Toxic stuff, I like to use it above 85 deg F or let it sit in an insulated large box when its cold e. g. ottawa. The glue dries hard an brittle. tough on knives, and jointers . I resaw it on a carbide BS blade and sand to thickness on a thickness sanders. I dont like to heat it past 350 deg on my silicone heating blankets . I/ve tried all the other glues including fish and this one worked best for me. It is a powder, and needs to be mixed to the consistency of heavy cream, and you need to wait before applying., A heavy glue coat ensures good coverage for the exotics I use. Bon chance.
These users thanked the author Ernie Kleinman for the post: jfmckenna (Mon Oct 25, 2021 9:58 am)
PostPosted: Tue Oct 26, 2021 10:43 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Thanks all. that gives me some encouragement it's possible.
Mike McNerney
